tbone1980
I have a 1982 with the stock bs34's on it. When cleaning the carbs the first time I noticed that one of the mixture screws on one side had a stripped head. After not touching the screw after multiple cleaning I eventually said I had to do something about it especially after I switched to pod filters with a new exhaust and needed to make adjustments. After letting it sit in blaster solution and trying to use an extraction bit with no luck I ended up having to drill out the thing. After drilling out the middle of the screw I still had a small amount of brass or what every it is let in the threads of the hole it screws into. Does any one know what size tap I can use to clean out the threads?
