I went through the thread and I really don't have much info on the EFI conversion. So here it is.
Parts list:
02 GSXR600 ITBs
BS34 carb boots
GM intake temp sensor
GM manifold pressure sensor
GM LS2 coils
suzuki throttle position sensor
suzuki injectors
custom drilled fuel rail
2" 36-1 trigger wheel
quantum hfp389 fuel pump
ninja 650 FPR in custom housing
Microsquirt ECU
GM coolant temp sensor modified by thedubshop for aircooled VWs
spartan 2 wideband o2
Process:
The outer pair of ITBs were split off the rack and respaced to fit the XS, this just took 2 spacers and 2 longer bolts, but needed a bit welded on to have the throttle linkage move both. I mounted the boots upside down as well and the ITBs, mostly for fuel rail clearance. The fuel rail is a piece of extrusion that I drilled to work with the injectors that came with the ITBs. Trigger wheel has an aluminum piece that lets it mount in place of the advance mechanism, and it is read by an allegro ats627 sensor in a custom m12x1.25 bolt. fuel pump as seen above in this thread is set up to mount in the tank. It is all wired up using the msextra manual and code.
Parts list:
02 GSXR600 ITBs
BS34 carb boots
GM LS2 coils
suzuki injectors
Microsquirt ECU
Process:
