1. Dismiss Notice
    Dismiss Notice
swing arm pivot width dimensions
Discussion in 'The Garage' started by Jack, Dec 3, 2019.
  1. Jack
    Jack XS650 Junkie Top Contributor
    I plan on swapping a Xs into a Z650 0r Kz650( are they both the same:umm:) if I can score one this coming year with intensions of swapping out the front forks and swing arm. While searching for a doable S/A swap
    I can across this thread of S/A dimensions that others might find useful in limiting their search.
    http://www.xjrider.com/viewtopic.php?t=3136
    gggGary likes this.
  2. TwoManyXS1Bs
    An interesting list, saved a copy, thanx Jack.
    It's missing our XS650 swingarms, which would have a nominal width of about 200mm.
    gggGary likes this.
  3. Jack
    They have the XS650 listed at 190mm, not sure how accurate the others are but atleast it gives something to go by.
    This is what I want to build except with a XS . All ready have the aluminum Fz600 arm with linkage modified for a 8 degree S/A angle, just hope I can get a 34 to 36 tooth sprocket for the FZ wheel. These Kz frames have wider opening in the back allowing a much longer manifold to be used plus I just like the looks of the older KZ's
    TwoManyXS1Bs likes this.
  4. azman857
    azman857 '80 XS 650SG Rider XS650.com Supporter Top Contributor
  5. Jack
    Thanks that's what I figured.
  6. Jack
Share This Page
