Roco22
Thanks, for being on point....It's been done using flex tubing,check out the Aussie xs650 forum
To all who responded...thanks for your contribution.
NO,the balance tube's job is to aid in balancing out the imbalance pressures of the cylinders to enhance
scavenging which in return boost low and mid range performance and lowers exhaust tone.
That said I have a TX750 AND a radian swing arm and haven't put either one on a runner yet.
Thank you for your considered input.Near the engine cross overs were all the rage for a while, so were air forks LOL.
I ride a stock 79 standard with the crossover and one with MikesXS commandos A-B, can't tell the difference. Except the stockers sound a bit better (lower tones)
Since the XS is 360 firing, the crossover theoretically doubles muffler volume, halves exhaust velocity. For great sound nothing else touches the early, no cross over, baseball bat mufflers. So THERE! I'd take a stiffer swing arm over the crossover. That said I have a TX750 AND a radian swing arm and haven't put either one on a runner yet.
Wishing I'd skipped the brace and only replaced the bushings....live and (hopefully) learn.once had a lot of ideas about improvement to the XS650. Every time you make one, you run into another shortfall. I've decided the XS650 can benefit from modest improvements, but may be best enjoyed as the engineers designed it. JAT
AFAIK mikesXS is only game in town. His look great, they are heavy, appear well made. But the pair I have hasn't left the shelf (yet)Suggestions for aftermarket "baseball bats"...
Anyone, anyone...
I'm confused....friends bike runs better with or w/o crossover?Cut the tube and plug, do it in such away it can be rebuilt if wanted. never had the experiance of the difference on the same bike. A friend has a C and had a set of aftermarket C-F mufflers without the crossover. Found a set of NOS C-F mufflers with the crossover, and without any other changes to the bike, he said it ran better and seemed to smooth out the rough edges..............he rode the bike to work every day so definatly had recent riding as a gauge.
Can ya give me a link...no can find...ThanksIt's been done using flex tubing,check out the Aussie xs650 forum
Here you go just scroll down. I personally would of gone bigger for greater flow. You want the tube close to the port like this to take full advantage of the scavenging pull on the port. There are no formulas that I know of that would suggest what pipe size is the best for effectiveness,trial and error would come into play.Can ya give me a link...no can find...Thanks
The exit tube from each muffler has a plate welded at the end in aside the mufler. You can knock off this plateThe exit tube from each muffler has a plate welded at the end in aside the mufler. You can knock off this plate and the sound and flow will increase. I loved thwesound from my stock 77 muffs with the plate knocked off. People would ask with great respect, "Is that the original muffler?" Yes, they sound good! I did have the crossover.
The crossover is to have each cylinder go through both mufflers. Less restriction and more souyn surpression.
Tom
Hi TimeMachine,Sounds like it requires removing the mufflers first ? Is that so ? Otherwise this plug would be left to rattle inside ? That's what I'm hearing.
