1. Dismiss Notice
    Dismiss Notice
Take Apart The Turn / Brake Tail / Headlamp Module Cover?
Discussion in 'The Garage' started by RonXS, Jun 30, 2020.
  1. RonXS
    RonXS XS650 Addict
    Has anyone taken apart the cover of the Turn / Brake Tail / Headlamp Module between the Tach & Spedo?
    [​IMG]
    I'm looking to put a small digital volt meter in the 'Brake Tail' spot behind the clear plastic panel. The cover has a 'faceted' red plastic piece sandwiched between the white reflector plastic and the clear plastic panel. The white reflector appears to be molded into the black cover. This will make it quite hard to remove. Just looking for ideas on how to remove it.
    BTW... I've changed out the Brake & Tail light to LEDs so I expect the module lamp to light up to indicate a fault all the time. So I'm going to repurpose this function.
    Jim likes this.
  2. Jim
    I've never done it, but someone here recently put one in there.... in the last 2-3 weeks iirc.
    So yeah.... it's doable.
    RonXS likes this.
  3. RonXS
    RonXS XS650 Addict
    Thanks Jim! I did a search, but obviously I failed at that! :doh:
    Did re-search :D and this is what I'm aiming to do...
    [​IMG]
    Photo borrowed from this post, from this thread.
    Also found some useful info here.
    Jim likes this.
  4. willis
    willis xsive compulsive disorder XS650.com Supporter Top Contributor
    Ron, have a watch here at Allen Millyard’s approach on his Kaw. Careful, you will get sucked into his other videos real easy.
    RonXS likes this.
  5. willis
    I’ve also got a spare in the parts bin. I’ll have a look at it tomorrow. I’ll offer it as a sacrifice to see if it will come apart before you dig into yours.
    RonXS and Jim like this.
  6. Jim
    I tried one of mine this afternoon. It's glued in all the way around. Tried to cut it out with an exacto knife. It's gonna take more than that. Maybe a dremmel with a grinding bit?
    RonXS likes this.
  7. RonXS
    RonXS XS650 Addict
    Success! I used a small round bit to dremel (thx Jim) out the lens from the back side. Once the red plastic lens was thin enough it started cracking. Then worked on it with a dental pick. After I got the first small chunk free, was able to pop out the rest rather quickly...
    [​IMG]
    Thanks for posting up the video Willis. :thumbsup:
    MrBultaco, lakeview and Jim like this.
  8. willis
    I took a little different approach since I’m out of dremel bits. I just armed myself with an exacto knife, two mini needle nose players, and a pick. I used the exacto to cut around the edges. Then pried out the white plastic reflector. I chose to use the headlight indicator for mine. It was a little tedious and it broke out in a lot of little pieces, but I got it. Note that the lens has two “tits” on the sides. These are recessed in the housing and glued in. I cut around with the knife and then popped the lens out. Wasn’t too bad, but I had to get a little aggressive. Took about 15-20 minutes total for removal.
    E9EC4564-0D39-42C8-AF52-59AF872CB254.jpeg 963A30B2-B221-4291-9A8A-B3BCC43621A9.jpeg 10127842-D91A-4322-92D2-0CD4AD6201F3.jpeg
  9. gggGary
    No need to remove the red lens ( he sez NOW) just mix up a bit of clear epoxy pour it on the facets I stuck the red volt meter right in the epoxy, done. When the bikes off no one can tell it's in there.
    RonXS, Jim and willis like this.
  10. 5twins
    19,415
    10,744
    813
    On a Special, you'll get your best and most accurate reading (closest to actual battery voltage) if you tap into the brown wire coming out of the ignition switch. Pretty much anywhere else you might tap into is going to read a few tenths of a volt lower because the power has passed through one of the 10 amp fuses and possibly multiple connection splits too.
    MrBultaco and RonXS like this.
  11. RonXS
    RonXS XS650 Addict
    Thanks for the info. I was planning on adding a BA9 socket connector like you did...
    [​IMG]
    Photo from this thread:
    '77-'79 Standard In-Dash Voltmeter
  12. 5twins
    19,415
    10,744
    813
    Well, that worked out fine on my '78 Standard but they're wired differently. The brown power wire for that bulb is about the first thing that branches off the brown power wire coming out of the ignition switch. It's not like that on a Special, you'll be passing through one of the 10 amp fuses. Your meter will work, it just may not read the actual battery voltage. The meter on my '83 was like that. It read several tenths lower than actual battery voltage until I switched the connection point to the brown wire coming out of the ignition switch.
  13. RonXS
    RonXS XS650 Addict
    Thanks 5T, I'll look for a more direct route to wire-up the meter.
    On another note...
    Adding this to the thread for those that want something small, non-digital and unobtrusive. Perfect for old things like my Giulietta.
    Found this post when searching on volt meters. Posted by this guy named 5Twins. :laugh2:
    [​IMG]
    650skull posted up a review link on Autospeed: http://www.autospeed.com/cms/A_113051/article.html
    Gammatronix
    Direct: https://gammatronixltd.com/
    Ebay Store: https://www.ebay.com/str/Gammatronix-Ltd-Electronics-Store?_trksid=p2047675.l2563
    Thanks 5Twins & 650skull
  14. 5twins
    19,415
    10,744
    813
    During the recent install of an on-off light switch on my '83, I had to modify the switch plate in the ignition switch. Besides adding a blue wire pigtail so I could send tail light power from my new switch, I added a brown wire pigtail for my voltmeter .....
    [​IMG]
    RonXS likes this.
  15. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    I think these meters look great...........looking at with the glass half empty ...........a taillight warning light isn't a bad thing.........if a car runs up the rear and their excuse is the light wasn't working???????............maybe that red warning light isn't so bad
Share This Page
