1. Dismiss Notice
    Dismiss Notice
tapered roller steering head bearings
Discussion in 'The Garage' started by Doug79, Dec 28, 2016.
  1. gggGary
    Yes the fiches from Yamaha have a few errors, specially watch out on 72-73 stuff. There are also a fair number of parts that only differ by color so the model listing isn't always the "whole story" Late model 4 pot calipers are one with a color "gotcha" There are about 4 or 5 color combos with different part numbers that are functionally identical. Yamaha doesn't ALWAYS keep to their own; color is digit X and Y of the part number scheme either.
  2. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    Hmmmm - all good to know. The chap who taught me about parts fish checked it yesterday and he confirms that it doesn't work the way it used to. I will switch to Partzilla.
    Pete
  3. fredintoon
    Hi Pete,
    dontcha just hate that? Folks "improving" stuff into unusability?
    I'm reminded of the WW2 Russian General who was in charge of weapon production.
    He had a big sign on his office wall that said:-
    Seek out those who wish to improve an in-place working weapon system.
    And shoot them.
    MaxPete likes this.
  4. MaxPete
    +1 on that Sir Frederick!
    When I worked in the petroleum industry in West Africa one of my colleagues (a Brit as I recall it....or perhaps a Yorkshireman...) had a sign in his Schlumberger wireline logging unit - right in the middle of the control panel - and it said in about 150 pt. bold-face font: "Do NOT touch or otherwise mess with anything in this truck unless you wish to buy it or eat it."
    Succinct, to the point, and easy to understand.
  5. joebgd
    joebgd XS650 Addict
    286
    65
    28
    NY
    I'm getting back into it after a few years off. I was way into it and did allowing the carbs bronze before things new bars etc. I changed to sealed bearings last project. I have to say the steering was like a rail b4 I messed with it. I have 2 say as of now I wish I left the original bearings. I don't remember using the seals on the intall of new bearings, maybe I did its been a while. I don't think I realised there were 2 sizes of bearings. Is it possible I installed them over opposite of the correct way? Will the bottom go In the top and top in bottom. Would they fit that way?
  6. gggGary
    Yes the inner races can be put in reversed. the roller parts only go one way. One of the races is taller than the other. You normally need to reset the jamb nuts after a few hundred miles, usually you have not fully seated the races, when they seat the bearing gets sloppy, usually a clicking or light clunk when you brake is the tip off.
  7. joebgd
    joebgd XS650 Addict
    286
    65
    28
    NY
    Okay thanks I think that's it. The steering nuts need 2 be tighter. I fealt that way already but the fella who inspected my bike wanted the steering loose enough to flop left and right.
  8. gggGary
    Just snug enough that you can feel a bit of resistance to the flop. You can take out tapered rollers with too much tension. Not an XS but I got blindsided and found this out by my usual method. :mad:
  9. angus67
    angus67 Welder's penetrate deeper!!
    Thats how we learn, gggary
  10. joebgd
    joebgd XS650 Addict
    286
    65
    28
    NY
    I'm just outside now getting her running. I messed might have 2 jump from a car battery. I went through about 3 glass mat batteries, the retailer had no problem taking them back but even though it's not used much it's been 2 long. The 4th or 5th one now just straight dead like It's open circuit. I think I'm going back 2 led acid. I'm get one 2day if it's in the cards.
    I'm looking forward 2 correctly tightening the steering and getting her on track.
  11. Zip960
    Zip960 XS650 Enthusiast
    I haven't ordered from PartFish lately, free shipping on Partzilla over $149.
    However, since buying a 1976 Yamaha Basket Case, I have noticed Parts fish does have a more complete parts list when compared to Partzilla. See below.
    As far as how to search for parts: Check out their tutorial in the SUPPORT TAB:). Its the last item, a you tube video.
    http://www.partsfish.com/page/website-tutorials
  12. Norton7d
    Norton7d XS650 Addict
    So if the tapered bearing sticks above the neck 1/8" or so, doesnt that then dictate the silver bearing cap that goes over the upper bearing is also above normal height, which would then mean the upper triple which sits in the silver cap is also above normal height, which would leave the gap between the upper and lower trees increased by a little, if so, can the headlight brackets which fit between the trees be expected to continue to have a snug fit with the space increased?
  13. Jim
    That wasn't my experience with the SG. It stood a little proud just as you say, but my headlight stays are still nice and tight. After I installed the tapered rollers, I worried about the too, but once it was all together everything was fine. Of course.... mileage varies.:rolleyes:
    GLJ likes this.
  14. Norton7d
    Well I got about 1/8" gapor so, I will try and run an o-ring on top of the bracket assembly to absorb, should be well disguised / hidden, but it is bothersome to have to disassemble again for something I could have predicted.
Share This Page
