1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
temporary fuel bottle for test running??
Discussion in 'The Garage' started by jeepguy, Mar 9, 2012.
  1. what to use for fuel bottle to feed carbs for test running
  2. littlebill31
    littlebill31 Smells of Raw Fuel
    I use an extra XS gas tank. Or a small 3 gallon red plastic tank used for small boats.
  3. Tack427
    Tack427 XS650 Addict
    on my old ninja i used to have.
    I used a 20oz coke bottle. I just drilled a hole and treaded a nipple in and added some jb weld.
  4. nice thats what im talking about
  5. grepper
    grepper fiddle futzer
    I have a tank off an old push mower, just bunji it to top frame tube. I have easy access to my carbs, but I have to remember I only have a few miles of gas. Found out them hard way.
    Posted via Mobile
  6. pamcopete
    pamcopete Ride.Enjoy.Life is Simple
    I just set the gas tank on a couple of high stools next to the bike and use a 3' length of fuel hose back to the carbs.
    Be careful using unapproved plastic containers because they may dissolve in gasoline, especially gasoline with ethanol in it. Now, before you say you have not had a problem, it's possible for the gas to dissolve just some of the plastic on the inside of the container and this dissolved plastic can then get in the carbs and gum up the jets and small passages.
  7. littlebill31
    That's exactly what I do.
  8. weekendrider
    weekendrider Iron Horse cowboy Top Contributor
    5,668
    1,119
    213
    S.W. MO
    +1. The plastic is designed for gas, it already has a spigot and capped hole.
  9. gggGary
    gggGary Stop that! Top Contributor XS650.com Supporter
    +3 Push mower tank with an inline shut off. I use it often enough that I welded up brackets to fit the XS650 frame so it stays put for around the block road tests and tuning tasks. I really like that it eliminates variables (tank rust, old gas remains, sketchy petcock action, clogged cap vent etc.) for troubleshooting.
  10. ReycleBill
    ReycleBill Part Time Tyrannicide
    Damn you, now there's something else I have to make for myself. Oh well, I need to practice my welding and brazing anyway. I say brazing because I'm sure my welding will leave holes in the lawnmower tank.
    I currently use a plastic gas can with a nipple in the bottom, a fuel filter and a cheap lawnmower petcock connected with clear line. But I don't use clear line on my bikes-- just on the test tank.
  11. gggGary
    My lawnmower tank is plastic and my fancy bracket isn't fancy in the least, but it has stayed on the bike during test runs, so far..........
  12. 5twins
    16,963
    6,097
    688
    Gary, I'd like to see some pics of that set-up. I have the plastic lawn mower tank, had it for years, could just never figure out how to mount or suspend it.
  13. Furious D
    Furious D XS650 Addict
    I have an old argon tank off my mig welder I built but have yet to use, The tank was out of certification so I upgraded to a bigger tank. Plan is to hang it above the bike table somehow. I'll take a pic when it is finished.
  14. cros36
    cros36 thread killer
    this is what i did last spring.
  15. littlebill31
    Here's my XS tank on the table with a long fuel line to my CB350.
    This is how I sync and work on all my carbs. I can reach the sync screw better and have total ease of reach around the bike while running.
  16. gggGary
    The plastic test tank/bracket, front "ears" were cut off a rusted out tank.
    The 79 fired and ran a few minutes ago. The mufflers blew mice nests out about 20 feet. NO SMOKE. It had been a long time since it last ran. Only 10K on the clock.
  17. RFLIVES
    RFLIVES Resident Sidecar nut
    Go to advanced and they have a universal coolant over flow bottle kit. Works great and is cheap
  18. Ghetto
    Ghetto Bob it!
    Gear Oil container.
  19. Bigfeet
    Bigfeet to many projects
    I do something similar. I put a threaded nipple in the cap of a gatorade bottle. Fill the bottle screw on the cap and after you invert it poke a hole in the bottom for a vent. When your done throw out the bottle and keep the cap. My wife says it looks like I have an IV bottle hooked up to the bike. lol
Share This Page
