1. The 2018 XS650 Calendars have shipped! Miss the pre-sale? Order one of the extras today!
    Dismiss Notice
  2. Thank you everyone for the donations to help keep the lights on here!
    Enjoy XS650.com? Consider making a donation to help support the site.
    Dismiss Notice
    Dismiss Notice
Testing my starter gear
Discussion in 'The Garage' started by xs650dude63, Oct 19, 2015.
  1. xs650dude63
    xs650dude63 XS650 Addict
    I just finished putting in my new starter gear, actually just the clip I had to reuse my old gear, how do I test it before putting the side cover back on to make sure it is working properly, unplug the spark plugs??? Thanks!
  2. TwoManyXS1Bs
    TwoManyXS1Bs Kablatta, kablatta...
  3. xs650dude63
    Thanks, but should I disconnect something so the engine won't start, since I have no oil in it.
  4. TwoManyXS1Bs
    Definitely pull the spark plugs...
  5. Spockwerks
    Spockwerks NAMAZU Pez de Terremoto
    Ditto, and if you are running any kind of aftermarket ignition, pull the ignition fuse so the circuit board doesn't toast.
  6. How long has the oil been drained out 63?
  7. 5twins
    5twins XS650 Guru
    14,176
    1,486
    213
    You can measure the tension on the drag clip using a fishing scale. That way, you won't have to do any of that motor cranking. Details are here .....
    http://www.xs650.com/threads/starter-gear-fix.18060/
    Many times a brand new drag clip is too weak and needs to be tweaked.
Share This Page
