- Messages
- 683
- Reaction score
- 1,477
- Points
- 143
Oops!
Your 77 is spoiled rotten with all the good stuff ! Such nice clean work too
But...one of these days maybe a High Zoot Rotor in there ?
Lk close
Great to see you successfully tackling this swingarm bushing job, Bob !Well thank you 5Twins for the timely posts! I’m just getting to that point , that I’ll be doing exactly as you have recommended.
So I’ve been chipping away at some things.
Yesterday, I cleaned up the rear wheel, checked the spokes for tension, and installed my new 31 tooth sprocket. The rear wheel is now ready to go.
After that I wanted to bleed my front brakes , since I’ve installed a new longer brake line. About three hours later I was done!!! I’ve got a vacuum pump I use, but I’m thinking about , the next time I do this, trying the old reverse bleeding technique.
View attachment 161222 “You almost fooled me with the old reverse bleeding technique!”
You know, where you push fluid up from the bleed screw , up and out into the reservoir.
Anyways I finally got a nice firm lever feel doing it the old fashioned way.
Today, I went out and started cleaning my engine case around the drive sprocket, which I have yet to change.
I then spent a little time extending my brake switch wire , for the master cylinder. With the new bars on it was several inches too short. That’s all done and tested and it’s good to go. About that time the mailman showed up with my new bronze bushings.
Everybody has their own way of doing these, as for me, I just grease em up and crank em in using a piece of all thread. Everything room temperature. I had them installed 30 minutes after I opened the box. I grease the inside of the swingarm, the bushing, and even the all thread to make the nuts turn easier. Do one bushing at a time and do the cranking from the bottom, or opposite side from the bushing. That way it pulls straight in, sometimes if you turn the nut near the bushing it will want to walk around and it can get the bushing cock eyed.
View attachment 161218 View attachment 161219 View attachment 161220
After the bushing was installed, I slid the pivot sleeve in and measured the end play with a feeler gauge. I didn’t photograph it, but it has .007 inch of freeplay. Beautiful!
Next up, I will be doing the 5Twins swingarm grease mods as mentioned above, and getting all my parts painted.
Until next time,
Bob
I hate to mention it, but do I see some grime in your left hand sidecase?
I checked the swingarm in place again and I realized I could still access the zerk fitting in that position so I left it. It won’t be too noticeable.
I wouldn't put that extra shim you have inside the grease seal. That would eliminate that .007" difference in length between the swingarm w/ bushings and the pivot tube, or most of it. You want/need the pivot tube to remain longer than the swingarm assembly for the set-up to install and work as intended (pivot tube clamped between frame so it doesn't move, swingarm w/ bushings rotates on it). If you must add a shim, put it outside of the swingarm w/ grease seals installed, like Jim did (post 96). But if a thin shim of a few thou is all you needed to snug things up, you probably don't need it at all. I'm sure the frame will easily suck in that much when tightening the pivot bolt.
I do like the idea of a shim washer like Gary and Jim use if the space is very large. As mentioned, this seems to be a problem mostly on the later models.
While you're watching paint dry... , take Elvis to the hardware store and grab yourself a 90° zerk. It'll make life much easier come lube day.
Grab yourself a snack while you're at it. I find that a small bag of hot pork rinds makes paint dry much faster.Now that’s an excellent idea!
Rear chain guard bolt.Mailman,
I just have to ask; where does that "arrowhead" shaped washer go?
I don't think I have one like that on my 77.
