rude
excellent job!
excellent job!
Will you be welding the mounting arm to the frame? Or how do you keep it from rotating down?
As always, this build is shaping up to be a quality piece of work. Loving the "workshop" facilities - much respect for having your shed set up to look like somebodys apartment
I love seeing pictures of peoples build inside their houses. When I was in my teens I build a Ford engine in my fathers living room.
G'day Torotor.
Thanks for the great feedback mate.
You're right about the plastic cable tie being a bit dodgy. I'll need to find something more durable that will allow me to mount the switch in the same fashion. The actual mechanism works really well and is easily adjustable in this configuration.
Cheers
Steve
http://inmotionphotogxs650.blogspot.com/
If you are going to stick with this method of mounting, maybe switch to a stainless cable tie? Also maybe check out Mikalor hose clamps ( http://www.mikalor.co/mikalor-gold-clamps ) to replace the jubilee clip, Mikalor's are much tidier in appearance and are available in a range of styles including stainless and gold.
Silencers look sweet and are nicely different from what most people are doing on this type of build
