I've been watching your build from here: http://billysmotorcycles.blogspot.com/ for quite some time.
PS. It's a little trickier but those drift pins can also be installed from the back so there's no hole visible from the outside.
I'm wondering of NSW would allow taillights mounded on both sides of the bike instead of one side? I'm sure their reasoning is that side mounted lights can't be seen from certain angles but a small light on both sides wouldn't have that problem.
Here in the US it varies from state to state. I'm assuming it's the same where you live.
If they will allow red instead of amber turn signals then you could use dual filaments and reduce the number of lights to 2.
Of course, there is the problem with the license tag...
PS. Is that a modified mustang tank?
1 of worlds problems is career politician.
the stupid rules n regs drives me so crazy
you have a fine work of ART Bro ,Ed
2.1.8 Rear Vision Mirrors
A motor cycle and motor tricycle built before July 1975 must have at least one mirror on the right hand side.
A motor cycle or motor tricycle with one front wheel, built after July 1975, must be equipped with two rear vision mirrors symmetrically placed relative to the centre of the handlebars.
The rear vision mirror or mirrors must be fitted so as to allow the rider to clearly see, by reflection, the road behind the vehicle and any following or overtaking vehicles. For circular mirrors the reflective surface area must have a minimum diameter of 94mm and for non-circular mirrors the reflective surface must be not less than 78mm in diameter and at least 120mm by 200mm.
If a mirror has a convex surface it must have a radius of curvature not less than 1200mm.
Motor cycles and motor tricycles may be fitted with additional mirrors that are flat or convex or a combination of these surfaces.
