Another Throttle question.
Currently I have a Motion Pro Throttle assembly running a CB350 2-1 cable into unlinked BS38s, as I saw someone mention it here.
The problem is I'm also using a Mikes aftermarket RH switchgear.
https://www.mikesxs.net/yamaha-xs650-bar-switch-brake-side-black-76-78-oem-584-83963-00-00.html
So it seems very crowded on the RHS with the throttle tube overhanging and the front brake lever reaching halfway across the throttle.
Should I just try to get an original throttle/switch and use that.??
cheers
Koyuga
cheers
Koyuga
