1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
Tire pressure
Discussion in 'The Garage' started by scott s, Apr 6, 2013.
  1. Greyandridin
    Greyandridin Got nothing to do and all day to do it
    Thanks
  2. delagem
    delagem XS650 Addict
    Standard advice from any tire guy at the race track. That'll get max grip. If you want longer tire life, you'll have to forego some of that grip, and raise the pressure a bit.
    grizld1 likes this.
  3. grizld1
    grizld1 Grumpy old man Top Contributor
    Beware of bad readings, the pressure gauges available today are crap. I buy three at a time, check them against each other and the gauges I have on hand, and pitch the ones that don't agree with the consensus. For gauge inspection I use the valve on a 5 gallon air tank, since it doesn't take much air loss to change the pressure in a small tire significantly.
    MaxPete likes this.
  4. XSLeo
    Even if your gauge is off a bit, as long as it reads the same every time is the important thing.
    If your gauge is off by a lb or two that's ok. Using the 10% method allows for that.
    I tried an electronic digital pressure gauge. Thinking that would be more precise. Checks pressure ten times such as grizld1 does and I get ten different readings. If it was off les than a lb it would bother me much but it was off 2or3 lbs.
    It works as a paper weight,
    gggGary likes this.
Share This Page
