1. Dismiss Notice
    Dismiss Notice
To Split, or Not To Split (was broken sump bolt)
Discussion in 'The Garage' started by jetmechmarty, Mar 16, 2020.
  1. gggGary
    JM do the head stud retorque on don's motor before throwing it in. and again at the first oil change flush.
    grizld1, jetmechmarty and Jim like this.
  2. jetmechmarty
    jetmechmarty XS650 Guru Top Contributor
    Do I have to pull the shift drum before it will come apart?
    grizld1 and Jim like this.
  3. Jim
    No, it comes apart with the drum in or out.... doesn't matter.
    grizld1 and jetmechmarty like this.
  4. Jim
    Marty, are you doing this with the engine upside down? That's the easier way in my opinion.
    jetmechmarty and 2XSive like this.
  5. Jim
    A big ol' chunk of wood makes a good upside down stand.
  6. jetmechmarty
    It comes up about two inches, hangs up, then goes right back into place.
    F36E67DF-1D8A-4161-A780-B0529D8D8500.jpeg C802B49C-A128-45CA-917D-5488B037C356.jpeg
    madmax-im, Jim and gggGary like this.
  7. Jim
    Remove the shifter linkage. Maybe that's catching?
    grizld1, jetmechmarty and gggGary like this.
  8. jetmechmarty
    Yes Jim! With Robin’s help, it lifted off. She held the shifter off while I lifted.
    :rock:
    lakeview, gggGary, grizld1 and 3 others like this.
  9. jetmechmarty
    $15 and it’s fixed. He used the method described by Leo. So, get the upside down lump out of my way and put the bike together is next.
    grizld1, Jim and gggGary like this.
  10. 5twins
    18,843
    9,652
    688
    Notice on the left side of your pic, that little black disc on the sealing surface just above the crank. Don't lose that, it blocks off an oil flow passage and must be there.
    nhsteve likes this.
  11. jetmechmarty
    No, I don’t see it. ?? There’s a black dot there, but nothing that comes off. :umm:
  12. jetmechmarty
    Going in, but I’m not going to get it this way.
  13. 5twins
    18,843
    9,652
    688
    On the left here, in the yellow circle .....
    [​IMG]
    And if that's not it, maybe it's stuck in the other case half (red circle on the right).
    gggGary likes this.
  14. jetmechmarty
    Yellow circle no. Red half went to machine shop and back.
    :er:
    I’ll find it.
    gggGary likes this.
  15. jetmechmarty
    This way is more promising.
    madmax-im likes this.
  16. jetmechmarty
    Engine in the hole with the first two mount bolts. I’m calling it a night.
    madmax-im, grizld1, gggGary and 3 others like this.
  17. arcticXS
    arcticXS XS650 Junkie
    SKF= Svenska Kugellager Fabriken. Translates to "Swedish Ball bearing Factory" Which was founded by the inventor of ball bearings. So yes, definitely a manufacturer of quality parts and tools. Equivalent of Timken, if not even better.
  18. jetmechmarty
    I’m not in the finished place I want to be, but the engine is in and much of the stuff is back together. I still have some of tomorrow.
    madmax-im, grizld1 and gggGary like this.
  19. jetmechmarty
    I’m running. I rode it 3 miles. I think it’s got exhaust leak racket going on. I hope it’s exhaust leak.
    JAX71224, madmax-im, 2XSive and 4 others like this.
  20. Machine
    Machine Race the wind Top Contributor
Share This Page
