Tombstone Tail Light Mounting
mrtwowheel
Honda Etched On Brain
Michigan, tri-state area
I am set on using a tombstone tail light on my TC Bros flat fender. The tapped mounting holes are at a goofy angle in relation to the fender. I realize that these tail lights are meant to be used with Harley's base but I see them on aftermarket fenders without the Harley base. Many that I've seen have additional brackets from the license plate to the fender. I am planning on fabricating a light bar for the turn signals and some bracketry to brace the license plate and light bar, got that figured out.
BUT, how is the tail light mounted to the fender? I don't see a way to use those goofy threaded holes to mount the tail light and there is only one flat surface molded in the tail light, not enough flat surface for new bolt locations. So, how is this done?
Scott
