Shipper
While rebuilding the transmission, I took the time to replace #4 gear in the starter complex as it showed significant wear. Not having the experience of knowing how the starter gears worked prior to tear down, I thought I might follow Tech Bulletin M5-071 (attached)
and replace the shaft clip accordingly even though it states 650c and not 650b, like mine. However, after trying it in place in looked pretty close to the top of the channel for the old clip. In fact, the old clip (when inserted into the channel) is close as well with apparent wear on the top suggesting it may?? have been dislodging. Both pics are with the gears pressed in against the casing.
Any suggestions?
Would hate to have to go without the electrics.
Any suggestions?
