Wanted - Transmission Main Axle (Late Model) + Engine bolt lower
wherearewe
Rub on Ya Titties
New Zealand
Looking for a main axle in good condition. 306-17411-03. Must be the late version to match my gear sets. The late version looks like the top one pictured.... You can see the difference at the clutch end. I live in New Zealand but have a proxy address in Portland so it can be shipped there.
Also looking for lower engine bolt. The long one that goes underneath the motor. 90106-10029.
Cheers team.
They seem to be pretty scarce wherearewe. One of my bikes was missing it and on the other it is sheared off.
Any bike salvage yards around you? I ended up getting a couple at one that need to be shortened a bit.
I checked at a local specialty hardware supplier and they could get them for me but wanted around $70 per bolt. Even a 3/8" Grade 8 bolt was a ridiculous price.
Here is a link to a thread from last fall where there was some discussion on the engine mount bolts.
http://www.xs650.com/threads/bottom-engine-mount-bolt.50741/
Good luck with your search!
This is marked as from a 1976 tranny with 2-3 bent shift fork???
bolt is checked correct bottom mount. make an offer would gladly sell complete tranny also.
Both bearings there also, removed for better view of shaft ends.
