trolly rail
I can only assume you're taking about mounting a ceiling hoist onto a trolley rail so you can move things around the shop easier.. Is that what you're looking for?
- if you only wanted a straight line you could make one using an I beam...building a 'trolley' to fit wouldnt be difficult
- if you wanted sideways movement too you could mount the beam to 2 others in the same way
Good idea about making an H with the I-beams to have movement in all directions.
