trouble understanding 277 pamco install
rugburn
As best I can tell my cam timing is spot on. Trying to walk the motor around to find the fire spots are where there supposed be. When a magnet passes a pick up it fires the coil right? I'm dumb help
rugburn,
Yes. The first magnet turns the coil on and the trailing magnet turns the coil off. The spark occurs when the coil is turned off. This happens on both pickups, like they were separate systems, which they are.
The second magnet is 90 degrees after the first.
Thanks Pete. That's exactly the in do I needed. I have to say you, Hugh, mmm are the most responsive dudes ever. I bet that magnet did bit was on your site. I'm all add and missed it. Thanks again.
