1. Dismiss Notice
    Dismiss Notice
trying to think of a way to wire up my new headlight
Discussion in 'The Garage' started by bergoff, Apr 14, 2013.
Tags:
  1. bergoff
    bergoff XS650 Addict
  2. TwoManyXS1Bs
    Hi, bergoff.
    That is a cool headlight. I've been wanting to upgrade as well, original 42 yr old bulb gotta blow soon.
    Long time ago I built a daylight sensor that controlled dome light delay in my hotrod.
    So, what about a daylight sensor to control the halo ring?
    You have enuff room for that 4" depth?
  3. TwoManyXS1Bs
    PS...
    Here in TX, headlights must be on at all times (only if newer than `74, I'm excused)
    If it were down here, I'd probably use a simple relay, halo ON unless H4 ON, then halo OFF.
    Subscribed...
  4. pamcopete
    pamcopete Ride.Enjoy.Life is Simple
    Use a latching relay that operates and latches the first time you select Hi beam.
  5. TwoManyXS1Bs
    Somebody showed up early for work...
  6. bergoff
    Its going to be close. And if it don't fit I'll send it back.
    Pete I had no idea what you were talking about. But thanks to you and Youtube I understand and its so simple its brilliant. Thanks man!
  7. pamcopete
    Well, here is a possible wiring diagram using a DPDT 12 Volt relay:
    [​IMG]
    1. When you first turn on the headlights switch, the +12 goes through contacts A to B to power the Hallo.
    2. The first time you select Hi Beam, the +12 goes through the diode to the coil of the relay and powers the relay which switches contact A from the Hallo to the low beam filament of the H4.
    3. Contacts D and E close to provide power to the relay coil so it will stay energized.
  8. bergoff
    Thanks Pete that makes sense. I should be able to figure that out.
Share This Page
