1. Dismiss Notice
    Dismiss Notice
TT pipes
Discussion in 'The Garage' started by Dogger, Jan 23, 2010.
Tags:
  1. Dogger
    Dogger XS650 Addict
    Hello,
    Just wondering if anyone here has run TT pipes. I have MikesXS 1 3/4" stainless pipes with taper tips on them. It's incredibly loud and I'm not that fond of how they look. I was thinking about dropping the mufflers and using baffles from JC Whitney that are inserted in the pipe. Would even like TT pipes better. Just want to be a little quieter. Any suggestions?
  2. big al
    big al XS650 Member
    Make your own baffles it's going to be a lot better.I've put those baffles in pipes and wound up with bkies that sounded like s##t .If you make your own and don't like them you can just toss them and try a different design untill you get the sound you want.
  3. eric123
    eric123 XS650 Enthusiast
    You may want to try the old washer(lolli pop/snuff-r-nots) trick. It may be just enough to take the edge off the noise...And its cheap :thumbsup:
    My apologies for not posting an intro...I figured no one cares and it would just clog up this board...If I am wrong, let me know...I use the same username at 650rider(RIP) and XS650garage FWIW...
  4. Dogger
    Dogger XS650 Addict
    Thanks,
    I've heard of the snuffrnots before. Something about attaching a washer on a rod that goes through the pipe. Then you rotate it to get the desired sound?
    I love the look of open pipes, and I've had problems with the mounting brackets on mufflers cracking (someone told me these bikes shake a little, haha), I just don't want quite so much noise.
  5. pumps
    pumps XS650 Junkie
  6. txpowdercoater
    txpowdercoater XS650 Addict
    206
    0
    16
    I made some washers for on of my evo's with 1/4-20 bolt and a washer welded to the head, then I could turn, tune and tighten.
  7. gordonscott
    gordonscott XS650exhaust.com
    Hi Dogger, If you have the taper tip mufflers on there now and it's too loud then you won't be happy with any slide in baffles or home made fix. To quiet it up more then those taper tip mufflers you would need a muffler that you can't see strait thru. I have used strait thru glasspacks and they sound nice and deep but after a while of use they can get just as loud as a taper tip. Sorry not much help but if you want quiet, real mufflers are (almost) the only way. p.s. OK I said almost? Just for fun I will tell you the "almost" part :D Sound comming from two points at the same frequency if facing each other will cancel each other out. So if you had the pipes bent at a 90 so they faced each other it would get quieter. This works because it puts the sound 180deg out of phase. I was in the audio business for 15 yrs :wink2:
  8. Dogger
    Dogger XS650 Addict
    Thanks, for the input. I think I have a new idea now. I would like to try a set of cocktail shaker mufflers. Any one know of a quality source? I figure this is going to be a hit and miss experiment till I find what I want! So far the taper tips aren't doing it for me. Plus they look way to much like something from a HD.
  9. gabes50
    gabes50 XS650 New Member
    4
    0
    1
    Does anyone know if there are true triumph style TT pipes avalable for the XS 650?
  10. grizld1
    grizld1 Grumpy old man
    Hoos Racing has 1-3/4" pipe sets in plain steel or stainless in 3 patterns including TT pipes, for a very reasonable price: www.hoosracing.com . They'll work best with EPO and TPO inserts from 650 Central.
  11. gabes50
    4
    0
    1
    griz thanks for info
Share This Page
