Scrambled
Motorcycle Man
Any updates on how your clutch set up worked out ? I am thinking about copying what you did, coupled with Ippytattoos 8 pack and Barnett springs .
Im interested on the turbo setup. Why is the mikuni not enough? Also, any reason you didnt try a draw through setup?
I wonder if you could get away with no fuelpump. Even with the turbo, I cant see it dumping fuel faster then you could feed it.
Also I know that when tuning my dsm. The stock turbo t25 was designed to see oil pressures of 100psi+ while upgrading to an evo 16g I had to reroute the oil feed to a much less 10psi location. One of them was ball bearing but I dont remember which.
Those turbos also had coolent lines so you werent relying on oil for cooling.
Thank you all for the compliments
Lowlife rat I am a career firefighter as well as a call lieutenant on another department and to add to the confusion I am also a firefighter in the Air Force Reserve. On the side I do all my woodworking.
Hey Wallywheels,
I was a firefighter in the Air Force Active Duty for 4 years! What base do you work at? I was stationed at Moody AFB GA. btw- Crazy bike!
tank has 2 drips I hope they will sand out if not, on goes the third coat.
