rmclaughlin
Hey all. 79 XS650 Special. Was wondering if I can resurface or turn the discs on my bike or should I get new ones.
Thanks
Rob
Thanks
Rob
The hole size when drilling should not exceed the rotor thickness. Holes up to the thickness increase surface area, this increases cooling, going larger than thickness decreases surface area, this decreases cooling. - - -
Hi Leo,
According to my mathbox, the break-even diameter for a 6.5mm thick plate is 13mm.
So you are a little ahead even with 1/2" holes.
And yeah, slotted rotors are great but there's very few XS11 donor bikes out there compared to the number of XS650s that need the slotted rotors, even if one XS11 can supply two (or even three if you get clever) XS650s
That or have a "Bro with milling machine."
You have to balance that surface area for cooling against the area for braking. Not sure how you got to 1/2" holes but about 90 percent of us use 1/4 drill size for this. There's been a couple of Swiss cheese jobs posted on here with 5/16 and 3/8 holes. They look WRONG! Just putting it out there. 6 mm is around .240 diameter. 1/4" (.250) just a tad beyond, but looks good, and works good.
...And I can't go with 2many's thoughts on a brake disk's effectiveness as a thermal sink neither.
Sure, it is one, but that's far outweighed by how effectively it throws heat away into the air.
Check out modern brake disks, they look like effin' fretwork and got frilly edges on them, all to throw the heat away.
