I know this isn't an XS650, but similar BS38 carbs and looking for advice. I couldn't pass up a 1979 XS1100 for $200 with full Vetter fairing and hard cases. Haven't decided on whether to restore or part it out. Engine has good compression and spark so decided to tear into rebuilding carbs. The P.O. cranked all four pilot screws in so hard all needles are broken off and jammed bad into each carb. Tried tapping the broken end out using a 90 degree pic to no avail. Is the only option to drill or will that bugger em up bad? I have small jeweler drill bits but no drill chuck small enough. Are these carbs now toast? Any suggestions?
