1. Dismiss Notice
    Dismiss Notice
US/UK model differences
Discussion in 'The Garage' started by Willholmania, Sep 16, 2020.
  1. Can anyone explain the differences between my US spec 1977 XS650 D (imported from the States a few months ago) and the equivalent UK spec model from the same year?
  2. Jan_P
    Jan_P XS650 Addict
    116
    134
    43
    Sweden
    Sir
    Not that easy to answer
    As I understand it in Europe has been sold two different engine types ( more if the Earliest models are taken into account )
    a so Called US model 447 Connecting rod and European model 533 connecting rod.
    https://www.xs650shop.de/en/search?sSearch=connecting+rod
    So to answer one need to Know what type was sold in UK was it US Spec or Euro spec bike.
    That year.
    Both perhaps.
    It was a while since i Checked this but If I recall right the Pistons at least differ looks that way on the parts link.
    Would be interesting to know why the difference was implemented and how it affects the engine
  3. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    This shows the different lengths of the rods.......Piston gudgeon pin hole position varies
    TwoManyXS1Bs and Jan_P like this.
  4. Is this because there's a compression ratio difference between US and Euro models?
  5. beano
    beano XS650 Enthusiast
    81
    181
    33
    Ireland
    There’s quite a few,
    • Starting at the front the euro model has twin 267mm disks compared to a single 298mm on the American version.
    • The master cylinder is 11/16 (17mm) compared to 14mm on the US machines
    • Stock European model handlebars were also slightly lower and forward of the US bikes.
    The frame has many differences.
    • Steering angle is slightly steeper on the Euro models 63.3 degrees and 108mm trail vs 63.0 and 115mm.
    • The Euro models also have an extra brace welded between the downtubes underneath the front engine mount and extra gussets welded between the backbone tube and the seat tubes behind the carbs.
    • These rear tubes are also welded to the central backbone with thicker half tube sleeves.
    • There is also extra reinforcement in the right hand swingarm mount area.
    • Moving on to the engine, as stated above the Euro model came with different pistons, rods and crankshaft.
    • Different paint options
    Hope this helps.
    Jan_P likes this.
  6. beano
    81
    181
    33
    Ireland
    Compression ratio should be the same 8.4:1
  7. Interesting stuff - thanks a lot for taking the time.
    I wonder why Yamaha would bother with all those differences? Seems like a lot of trouble to go to.
  8. Jan_P
    Jan_P XS650 Addict
    116
    134
    43
    Sweden
    I have an 1980 --- XS 650 SE US Custom ,,
    without the new type alternator
    with points ignition ( from factory ) and have 533 Con Rods.
  9. Clear as mud then!
  10. 650Skull
    I didn't know they came out with the 553 motor.........We also had points on our bikes down under until the end of production in 81
    It is if you realize the US custom was made for the European market and not available in the US
Share This Page
