sc-xc
Hello to all, I am new to the forum and a friend who works for a motorcycle company is letting me into their overstock. All prices are exactly what I can get them for, I just wanted to pass on a cool deal. Please let me know if you have any questions, I am not able to check this everyday but will get back to you ASAP! Maybe faster if you leave a phone number. I am also open to trades.
I am able to get fork sets with triple clamps for about $150-$175 depending on quantity.
The forks are 29.5 axel to top
5 5/16 wide inside at axle
38mm slider with 48mm stay tube at clamp
28mm stem that is 6" long pressed into lower clamp
they use a 20mm axle.
The shocks are right about 10" long with adjustable comp/rebound with a 500lb spring
I can get them for about $55 maybe less depending on quantity.
The headlights are 7" diameter with a H-4, high/low bulb and a parking light.
I can get them for about $45 once again less with quantity.
The baja kits have no part numbers on them, they have a cool LED tail, the head light is 35w and them come with the wiring to install, a magnetic pickup speedo and a light control for the bars. You will need to provide a 12v power source.
I will find out about the light kits in the next few days.
