1. Dismiss Notice
    Dismiss Notice
Valve bounce, maybe? stuffed two valves!
Discussion in 'The Garage' started by kevski, May 21, 2020.
  1. grizld1
    grizld1 Grumpy old man Top Contributor
    Kevski, the thing that gives me heartburn with certain vendors is that they keep selling products that are known to be bad for years because they make more from the junk than they would from good items that are currently available. Then when I point out the defective item it often induces a shill to accuse me of making a personal attack on the vendor. Maybe I should just shut up and let guys waste their time and money. Anyway, I truly admire your tolerant outlook and even temper.
    Jack, your post indicates that you've already decided what to do with with that camshaft--use it for a doorstop!
    Mailman, GLJ and Jim like this.
  2. Jim
    I'd prefer both you and Jack continue to share your knowledge and wisdom with us. :D
    FLEA, JAX71224, lakeview and 4 others like this.
  3. grizld1
    Wisdom?! Thanks for the kind thoughts, Jim, but if any of us geezers had even a trace of wisdom we probably wouldn't be fooling with motorcycles, let alone old ones!
    buzzword, lakeview, Mailman and 2 others like this.
  4. Jim
    Yeah... good point. Suppose I could use my retirement years to learn how to paint dog portraits or sumpin'.... ;)
    grizld1 and Mailman like this.
  5. Mailman
    thuban, cra-z1, GLJ and 3 others like this.
  6. kevski
    kevski XS650 Addict
    298
    253
    63
    kent uk
    Back to the thread and head, i checked the stainless valves in the stuffed head all within spec no oversize stems even the one that bent, so this head will go on the back burner, replacement head stripped cleaned threads chased, de-coked, what little there was, tappet cover stud repaired, valves cleaned checked then lapped in, re-assembled and put back on the motor, waiting on camshaft seals otherwise it would have been up and running tomorrow, will video it running when done.
    Mailman, thuban, Jim and 2 others like this.
  7. kevski
    kevski XS650 Addict
    298
    253
    63
    kent uk
    Back up and running today, put the motor in yesterday, this morning i was at it before 6am, every thing back on except seat tank panels and battery before 8.30, then off to work until 1pm, quick bit of lunch, then put on original side oil filter, tank and battery, few kicks to get some oil moving, plugs in choke on, second kick and fired straight up, settle to a nice idle, checked behind tappet covers to make sure a good supply of oil, strobed in, only a couple of degrees out, will balance the carbs after work tomorrow and get a video of it running, much quieter than before, and only cost around $200, struck lucky with the used head.
    Superjet, GLJ, grizld1 and 3 others like this.
  8. thuban
    thuban Horse Scratcher XS650.com Supporter Top Contributor
    That's great, kevski! We be waiting on the vids! :thumbsup:
    Jim likes this.
  9. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    Good for you!:thumbsup:
    Still would like to know how the valve got bent above the guide. I have seen my share of damaged engines. Never a bent valve on the top side.
    FLEA, Mailman, JAX71224 and 1 other person like this.
  10. kevski
    kevski XS650 Addict
    298
    253
    63
    kent uk
    Got a small video of cold start no choke with replacement head, done in the garage with phone so sound is rubbish, i balanced the carbs after.
    Jim likes this.
  11. bikefreakjon
    bikefreakjon XS650 Member
    20
    25
    13
    Idaho
    Maybe the piston tried to stuff the valve back up into the rocker?
    I'm trying to think if I've ever seen that and it's not ringing a bell..
    Xs valves are burly! Like Toyota 22r burly...
    Also heavy.
    Did we ever find out if the retainer failed or was improperly installed?
  12. kevski
    kevski XS650 Addict
    298
    253
    63
    kent uk
    All retainers and collects were still in position, all stems and guides in spec, only other evidence was a substantial witness mark on the inlet valve
Share This Page
