Always fiddlin' with the '83.
Had a bit of an oil leak around the left side, top. Cam cover or front valve cover. Had some down time from being on 'stand by' for work, so I decided to adjust the cam tension and valves, re-adjust the hang of the exhaust system too.
Got everything put back together and broke out the baby powder to check for the oil leak. Got the top left side powdered up real good and cranked her over. Started fine but ? Nasty tap from the exhaust valve area. Allright, pulled the plug and the alt and ehxaust cover, double checked the setting, a nice .006". Hmm, could it be? Put her all back together again, started her up and tried blowing smoke over the header flange...too breezy. A handfull of baby powder on the flange and a few revs of the engine and the culprit was found. Re-adjusted the header and all's well.
Now to see if the leak is resolved, just gonna have to tell work to 'stand by' while I do a 20 mile loop.
