Hey Gang, I bought these rearsets on eBay for cheap. The quality is not bad but I wonder about the fit. I think the linkage is supposed to hang down but since I have the stock exhaust that is not going to work. I have to mount the linkage on top.
Here is the right side:
The old peg mount is in the way so if I use these I'll need to modify the arm so it clears. I don't want to start cutting off stuff I may need later if these don't work out. Also the brake arm will need to be clearance.
Here is the left side:
Not as bad clearance wise but I don't know how comfortable it will be. I doubt I could get my toe under the shifter the way it is mounted. Since I don't have a seat yet I can't really sit on it and check it out. Losing the exhaust would help but I don't want to spend a couple of hundred on a new exhaust to accommodate $50 rearsets.
Suggestions?
Suggestions?
