Vlad
Loads of progress since the last update.
One of the battery cable terminals broke, and I was able to repair it by soldering a new terminal. It may not look the best, but it works and saved a few bucks.
Also, I decided to rebuild all the brake parts. At first I reused the original piston seals, but figured it was easier to just do it now while it's all apart. Ordered the wrong front master cylinder kit though so I still have to wait for that, but both calipers and rear master are done.
The wheel bearings in both wheels were also replaced. This probably wasn't necessary, but it was one of those things where I thought it would be easier to do now. The original bearings had the metal shields, and I replaced them with the RS rubber seal type, so they should hopefully last the life of the bike now, with re-greasing every so often.
Also got some new tires. Went with the Pirelli Route 66. Still have to seat the beads on the tires and balance them. I am using a Marc Parnes wheel balancer. It is excellent! Would highly recommend.
Not pictured is the rebuilt swingarm. The stock plastic bushings were removed and bronze bushings were installed. I also added a grease zirk.
Other than that, it was just a bunch more cleanup and polishing of stuff. I went through all of the rubber parts and hit them with some silicone spray, hopefully restore them slightly and increase their longevity. Here are some before/after pics of the cleanup.
I'm pretty much at the point where the cleanup is done! I did what I could that didn't require removing the engine from the frame. I worked on the parts that came off the bike also, making sure things were lubricated as they should be and straightened out a few dents. Everything is more or less ready to go back on the bike. These are exciting times!
Next Steps:
Electrical stuff - the previous owner junked the stock fuse box (which is fine) except that he replaced it with these awful in-line fuses that just dangle. So I'm gonna fix that, check each connector for any broken wires, and pack all of the connectors with dielectric grease.
Seat tire beads and balance wheels
Gotta rinse the gas tank with something. Did electrolysis rust removal but there's now some surface rust in there because I made the mistake of not filling it up as soon as the electrolysis was done.
Here's all the parts and how the bike is sitting right now:
Then, time to reassemble the bike!!!
Next Steps:
