Poverty
Wasn't sure if I should post this in the "how to " section or the "fab" section .. Hope this is the right spot ??
I picked up a super barn fresh wassell on the cheap ( hay and rat shit included!!) and had a few questions pertaining to it .. first of It has some funky DIY fisco job done to it .. after chipping the bondo out of the front channel and cutting out the sheet metal whoever abraised in ( this thing has more brass in it than steel) I come to the sad sight that the original channel is still intact but with about 6 torch holes cut into it (assuming its for the gas to fill the empty void ?) I would be embarrassed to say I did that kind of work on something but whatever you always have to fix someones mistake right ?
So anyways to my question ..since it seems it would bee more work and effort to save the original channel .. I planned to go ahead and redo the fisco mount with properly cut and welded sheet metal and wanted to know .. do I cut the original channel out on the outside of the seam or is there another way Im not seeing .. Not trying to screw my tank up anymore than it is highlighted in pic below
