PRoberts317
- Messages
- 12
- Reaction score
- 0
- Points
- 1
My first post here, hope you can help!
I bought my first motorcycle at the start of this summer; a 1983 XS650 Heritage Special. The bike seems to be in pretty good shape, other than a few electrical problems.
The bike wouldnt run when I bought it, then I had the carbs cleaned and rebuilt it ran wonderfully. At this point the bike wouldnt hold a charge, I thought I needed to replace the regulator/rectifier, then found out I actually needed to replace the charging rotor, so I changed them both at the same time.
*Now on to the real problem*
So at this point the bike is running around town pretty good for about 10 miles, then I decide to take her out on the highway for the first time. I run on the highway for about 10 miles, then about a mile after I get off the highway the engine starts to misfire a bit. At first it only misfires between 2500-3500 rpm (in all gears, including Neutral), but if I keep it about 3500 or so I can ride fine, up through all the gears. This continues until eventually I cant get the bike to revany higher than 2500 or 3000 rpm (top speed is about 35 or 40mph at 3000 rpm in 5th gear). The decline in performance was gradual although very quick, but not immediate (maybe a connection shook loose or something??)
My first thought was that maybe some crap from the old (original) air cleaners got stuck in the carbs, so i take the carbs off, clean them out (nothing in there), and replace the airbox with pod filters. NO CHANGE.
I talk to a few old gear-heads, mechanics, and the usual lot... Most advice pointed to my ignition coils. I ordered performance coils from Mikes XS, and to help add to my peace of mind I also ordered new NGK performance plugs, plug caps, and plug wires... Hooked everything up, still no change... Sputtering and puffing sound from the left cylinder and out the back end of hte carb.
Checked out the resistance on the pickup coil (both wires are the same at about 770 ohms)
I graba timing light (I did mess with the timing plate a bit while I was exploring and replacing the alternator rotor), and when I hook the timing light up to the left-side spark plug wire the light fires sporratically and rarely, and furthermore I cant get the timing mark to come to where it's supposed to be. Then I hook the timing light up on the right-side plug wire and the light is firing away like its supposed to, but I still can't set the timing and I still cant figure out why my left side isn't firing correctly..
PLEASE HELP, IM DYING TO RIDE!!!
