cros36
thread killer
so i took my bike out yesterday for its first shake down run. went out for 30 minutes. came home everything checked out good! went back out for about an hour and a half, everything checked out good! all the bolts stayed where they should, charging system was going good. let it cool down and had some dinner. went back out at about 11 pm for another hour and a half. about an hour into the night ride, my headlight started to dim so i started home, as quickly and safely as i could. when i got home i had a battery reading of 9.something. i was too tired to go any further with it then. this morning i come out to take a look at the charging system and the battery reads 11.35.
so to recap i guess last night it was 9.mid (sorry i dont remember) and today its at 11.35. i checked 3 legs on the stator and im getting 1.4 on 200 setting and 1 on the 2000 every way that i try. so im guessing that at least its consistant? what i dont get and havent every heard of is the battery gaining volts after its been ran. any thoughts on that? i will be checking two rotor rings, new brushes but ill check them as well.
heres a run down...
74
pamco w/ green monters
mikes agm battery
bs38 (before the night run i upped the pilot to help with minor short hesitation that was occuring around 1/4 throttle ((crusing around town speeds)) and went back to 3/4 on the mix screw, still needs some work...)
autolite 63's
single 12v 35/35w headlight (had high beem on till i noticed the dimming to conserve.)
single taillight trailer style.
heres a run down...
74
mikes agm battery
autolite 63's
