1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
what common tool to pull clutch pushrod seal
Discussion in 'The Garage' started by ckahleer, Oct 9, 2019 at 10:49 AM.
  1. ckahleer
    ckahleer XS650 Member
    I need to replace my leaking push rod seal.
    Do I need to get a seal puller or is there another way to get it out.
    Thanks.
    Jim likes this.
  2. Machine
    Machine Race the wind Top Contributor
    Since you are replacing it, you should be able to pry it fairly easily with a shaft smaller than the clutch rod ?
    Jim likes this.
  3. Jim
    Jim I have a plan. It's something to deviate from. Top Contributor XS650.com Supporter
    If you use the "Search Forums" button at the top of the page, you get tons of hits for clutch pushrod seal. There's even some video howto's in there.
    Machine likes this.
  4. jetmechmarty
    jetmechmarty XS650 Guru Top Contributor
    Booger hook (cotter pin puller) will get it.
    [​IMG]
    TwoManyXS1Bs and Jim like this.
  5. willis
    willis XS650 Junkie Top Contributor XS650.com Supporter
  6. Mailman
    1FDFA3B9-AFB3-481E-9ABA-CA816F138E45.jpeg 23773C7F-D11D-451F-A6A9-52864FFE0DA0.jpeg CBC9A5B1-7B2A-47CD-A4B7-F8AD66709024.jpeg
  7. gggGary
    gggGary Stop that! Top Contributor XS650.com Supporter
    I keep a slightly bent over, old flat blade screwdriver (heat with propane torch to bend). I also ground the sharp corners off. Pops the seal out easy.
  8. Mailman
    Well that just sounds too easy. Real men never do things in a simple way if there is a more complicated and expensive option available! :laugh2:
    Machine, gggGary, lakeview and 2 others like this.
  9. gggGary
    I bow to your near surgical technique and precision!
    Mailman and Jim like this.
  10. Jim
    Yeah... I usually just go all medieval on 'em....
Share This Page
