I have explained some of what happens several times. I thought maybe I should put it all together. I'll start with the early models, then explain the differences.
When you turn the key on power flows from the battery positive through a 20 amp fuse to the key switch, the switch feeds this power out on a brown wire. This is the main power feed, the brown wire feeds power to the horn, regulator, brake lights and switches. The red/white wire feeds the engine stop switch, the blue wire feeds the tail light, the red/yellow feeds the headlight switch.
I'll continue with the ignition circuit. Power flows out of the switch on the red/white wire to the kill switch, turn on the engine stop switch and power flows on the red/white wire to both coils. After the coils power flows to the points and condensers, now as you kick the engine over the points open and close. When the points are closed power flows through one of the coils, one coil is for the right side and one left. This power flow in the primary half of the coil builds a large magnetic field around the coil.
When the points open this field collapses. This collapse creates a large voltage in the secondary half of the coil, this large voltage is what jumps the gap of the spark plug. Then the gas/air mix in the cylinder fires and burns, making the engine run. The points, being two sets, with a single lobe cam alternately fire on each side.
Now the brown wire feeds power to the regulator. When you turn on the switch power flows out the brown wire to the regulator. At the regulator if this power is below the regulators preset voltage of 14.5 volts the regulator sends power out on the green wire and this goes to one of the alternator brushes. The power flows through the brush, into the rotor and out the other brush to ground at the stator housing, then along a black wire into the harness.
This flow of power creates a strong magnetic field around the stator. Now as you start the engine the spinning rotors magnetic field excites the stator. This excitement causes the stator to create an AC voltage. This AC voltage travels out the three white wires to the rectifier. The rectifier changes the AC voltage to a DC voltage to charge the battery.
As the battery charges, the voltage climbs, when it climbs to the preset 14.5 volts the regulator turns off the power to the rotor, the magnetic field stops, the stator stops making AC voltage/current and the battery stops charging. Now as the battery isn't charging the voltage drops, at 14.5 volts the regulator starts the charge cycle over again. The regulator does this hundreds of times per second.
As far as the rest of the electrics go, it's pretty simple. The horn power on the brown wire flows through the horn to the button, where it gets grounded to toot the horn. The lights are simple, power to the switch, the switch turns on the lights. The turn signals are a bit more complicated. Power to the flasher then to the switch, then to the signals.
When they added the starter they added a safety relay. When you turn the key on, (engine stop switch must be on), power flows to the starter relay through the safety relay. When the engine isn't running the safety relay is not powered, this lets power flow to the start button, the start button sends power to the start relay, witch in turn sends power to the electric starter. This cranks the engine. Then as the alternator starts to charge, a voltage is sent out on the yellow wire to the safety relay. This voltage switches the relay to stop sending power to the starter button, this disengages the starter and keeps the starter from working while the engine is running.
They changed the system a bit in 74 or 75. The power didn't go to the starter button but to the start relay, then to the start button, where the button grounded the circuit to crank the starter.
They added things to some of the systems. Mostly safety features, self canceling signals, clutch and side-stand switch's and relays to prevent starting in gear and riding with the side stand down.
In 80 they made a couple major changes to the bikes. They swapped the points for an electronic ignition. The TCI, (Transistor Controlled Ignition). As in the older system when the key is on, and engine stop switch is on, power goes to the coil, It also goes to the TCI box. After the coil, power flows back to the TCI box. There is also a pair of pickups in a small black oval on the stator that gets triggered by a small magnet that is in-bedded in the charging rotor.
Now as the engine turns this magnet passes the pickups. The pickups read the magnetic field of the magnet in the rotor and send signals to the TCI box. The TCI box uses these signals to know the crank position and the engine rpm's. The TCI box uses these signals to tell when the spark plugs should fire. When the TCI figures out when to fire the plugs, it turns a transistor on and off to turn the coil on and off, the same as the points did. The TCI being solid state has no moving parts to wear out so it doesn't need the constant adjusting and replacements that points do.
They also redesigned the charging system. They went to a solid state combo reg/rec. This new reg/rec works similar to the old reg and rec but has a few changes. Now as the key is turned on, power is sent out on the brown wire to one of the brushes, as well as the regulator, The new regulator reads just the battery voltage on the brown wire. When the reg reads a low voltage it turns on a transistor. Power flows on the brown wire to the brush, through the rotor and out a green wire to the regulator. When the transistor is on, it grounds the green wire, this creates the magnetic field in the rotor causing the stator excitement and production of the AC current, the AC current is sent to the rectifier and as in the old system, changes to DC current and charges the battery.
When the battery voltage reaches the preset 14.5 volts the reg turns the transistor off...power stops....no charge....voltage drops. Then repeats, the same as the old style. The solid state Reg/Rect can cycle much faster than the old mechanical reg, thousands of time a second......... Also no moving parts to wear out.
These changes to the system greatly reduce maintainable and greatly increase the reliability of the bikes.
If you can grasp these basics of how the systems work, then you can fix malfunctioning systems, and keep working systems working.
A link to some
Colored Wiring Diagrams., Jayel's album
Thank you for taking the time to read this, hope it helps.
