1. Dismiss Notice
    Dismiss Notice
Discussion in 'The Garage' started by I am Carbon, Nov 24, 2013.
Tags:
  1. YamadudeXS650C
    YamadudeXS650C Central New York XS650 XS650.com Supporter Top Contributor
    Sorta looks like Card #7 to me....
    [​IMG]
  2. robinc
    robinc Member of the 'yellow meter gang' Top Contributor
    Ah, ok Dude, but what does it tell you?
    Jim and YamadudeXS650C like this.
  3. YamadudeXS650C
    Seems to me Kawabunga is just as OCD as the rest of us are.
    And he probably folds his TP instead of crumpling it.;)
    Jim and robinc like this.
  4. kawabunga
    kawabunga XS650 Addict
    Nah, I'm a crumpler.
    But my stereo volume does need to be set on an even number.
    Shoot, maybe I'm more OCD than I thought... o_O
  5. Jim
    I fold nice and neat..... and LOTS of sheets.....:rolleyes:
    robinc, gggGary and YamadudeXS650C like this.
  6. Signal
    Signal XS650 Junkie Top Contributor
    You all have nothing to worry about. When you start calling it CDO it time to get help. COD is OCD in alphabetical order (as it should be).
  7. Mailman
    And the edges have to be squared up, and if a sheet doesn’t tear off straight, throw it away and start all over. Haha!
    robinc and Jim like this.
  8. gggGary
    Something about how this post is worded is bothering me...........
    [​IMG]
    TwoManyXS1Bs, Signal, robinc and 2 others like this.
  9. robinc
    Ah yes cap'n gggGary.
    Ask #1 to look into it?
    Or #2?
    gggGary and Jim like this.
  10. Jim
  11. gggGary
    busy busy today.
    20180417_093542.jpg more evapo-rust work, part way through those carbs and a successful float solder! Top of the left float at the bottom, used a 25 watt pencil and quick work on a incomplete seam solder.
  12. sean colleary
    sean colleary XS650 Addict
    nugs81, Guss80special, Meddy and 9 others like this.
  13. Jim
  14. ABill
    ABill XS650 Enthusiast
    Hey man, did you have to modify anything to put that seat on? Also could you provide a link for it?
  15. sean colleary
    ABill likes this.
  16. lakeview
    lakeview XS650 Guru XS650.com Supporter Top Contributor
    Left Hand Drill Bit save:
    They are promising a weekend without snow coming up, so I wheeled my 76 out from the shed yesterday and it fired up 8th kick. (PO removed starter, but installed a Pamco).
    Going over it for loose bolts, I tightened left fender stay mounting bolt only to feel that dismal release just before you were going to stop turning.
    The left over was just flush with the bracket so no vice grip clearance. Remembered that this site' s Sensei had spoken well of left handed drill bits and I had ordered a set of three so now was the time.
    The bit had barely started when the broken bolt started to turn out.
    It was a five minute fix and a win for today.
    MaxPete, Mailman, test dummy and 7 others like this.
  17. gggGary
    Been working on Madness, did some beating on the side covers so they fit the carbs, filters better.
    Went through several fuel line iterations, still not done with that. have the spoke, disk rear wheel on
    and the rear fender taillight changed, put a standard seat on and dropped it down on the frame. Got enough done to get it off the lift for a bit, so the latest beater can get a wake up drill. Then I rode it!
    Plugs are pretty white, not a plug chop, but it feels a bit lean too.
    It's been so long, I'll open the carbs and see what jets are in there. A bunch of details to go before it's trip worthy.
  18. Jim
    That rear disk setup looks sweet Gary!!
    robinc, Mailman and gggGary like this.
  19. Mailman
    Gary you got that beast looking like a real motorcycle again!
    Kinda miss that crazy spoiler though! :p
  20. ThatXS650Guy
    ThatXS650Guy More Sparky than Speed Racer XS650.com Supporter Top Contributor
    Added a larger XS1100 rotor to the rear of the 650. I used a rear caliper bracket from an 1100 and modified it slightly to accept the stock XS650 rear brake stay. I had to change the spacers a little but that was cheap and easy.
    I also added a different voltage monitor. I had red LED meter zip-tied to the handlebars but I wanted something less obtrusive. I grabbed one of these: https://www.ebay.com/itm/6v-12v-24v...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649 and added it to the panel since I wasn't using the center brake light indicator anyway. You can program it six different ways. I use the battery tender connection when riding and when it's off the tender so the monitor isn't on all the time.
Share This Page
