You can get the head off without breaking the cam chain:
http://www.xs650.com/threads/removing-camshaft-without-breaking-cam-chain.3940/#post-41482
By removing the bearings it allows you to thread the cam out.
Yup - and RobinC and I did precisely this on Lucille's engine last year. It works like a charm and it is an easy / no risk thing to do. Just BE CERTAIN to NOT drop anything down the timing chain channel between the cylinder bores. THAT would definitely generate a Class 1 OH F@CK moment and tears would ensue.
Now, since I eventually did have the cylinders bored and new pistons and rings installed, the timing (i.e. cam) chain was broken by the shop who did my engine, but the key thing is that you can remove the camshaft without breaking the timing chain. I have two additional points:
- If you're going in there to do this much work, it seems to me that doing the rings and bores is not a bad idea anyway. The incremental cost is not that much and then your entire top end is freshened up.
- Just in case you were wondering, what you canNOT do is remove the head with the engine in the frame. There simply isn't enough room between the cam cover and the frame backbone above the engine to get the cam cover and then the cylinder head out.
Pete
