1. Dismiss Notice
    Dismiss Notice
Discussion in 'The Garage' started by I am Carbon, Nov 24, 2013.
Tags:
  1. lakeview
    lakeview XS650 Guru XS650.com Supporter Top Contributor
    Have to keep remembering that this is a hobby and fun.
    buzzword and Mailman like this.
  2. jolo9534
    jolo9534 XS650 Enthusiast
    turned an old rear set as my jockey shifter IMG_6345 (1).jpg thumbnail (1).jpeg IMG_6345 (1).jpg thumbnail (1).jpeg thumbnail (2).jpeg thumbnail.jpeg
    stanleyipkis likes this.
  3. Mailman
    As my motor is in pieces because my stupid expensive gas tank with the crappy liner shit the bed and ruined my freshly rebuilt motor, and now I have to find , buy and repaint a new gas tank and I’m spending money like I have a never ending supply.........I too have to remind myself that this is supposed to be a hobby and fun! :cautious: Sometimes it just seems like an endurance test.
  4. Jim
    jetmechmarty, buzzword and Mailman like this.
  5. Pipes
    Pipes XS650 Enthusiast
    51
    150
    33
    Uk
    Today I got to work a little early and to pass the time I decided to see if my little lathe could turn down a stator cover to replace my tatty standard one.It was more of an experiment to be honest but I cut some aluminium (or aloominum for our friends over the pond ;)),welded a stub on the back and gave it a whirl in the Myford.To be fair it came out better than I thought so I may keep it.I quite like the 'billet' look.
    buzzword, gggGary, resto and 7 others like this.
  6. Jim
    Very nice!! Not to throw cold water on it, but did you check that it'll clear the rotor nut? I wanted to make sure there was clearance there so I used a 20T press to "dish" the blank before I turned it.
    gggGary, SEd27, Machine and 6 others like this.
  7. Pipes
    51
    150
    33
    Uk
    You are exactly right Jim....I noticed the crank nut has very little room tonight when I tried it on the engine.I need to cut off the slug on the back,put it back it the bigger lathe and remove a little from the back.
    gggGary and Jim like this.
  8. stanleyipkis
    stanleyipkis XS650 Enthusiast XS650.com Supporter
    59
    67
    18
    so cal
    I took a stab at doing a rear 4 pot caliper upgrade. At first I tried going thru the axle but ran into clearance issues. Welding a tab to the frame seemed like a good to idea.
    I just need to come up with a spacer between the axle and extend the caliper stay rod.
    Pipes, jetmechmarty and ThatXS650Guy like this.
  9. lakeview
    Mixed Bag
    Items that should not be co-mingled.
    Gotta look up the pictures of the different types of cam chain adjusters and combine the right bits.
  10. lakeview
    '75 Motor Buttoned Up At Last
    Going to use the tins in as found condition. Motor will be a candidate for the GN250 ignition and a set of linked carbs. Frame may get a set of 35 mm forks.
    Probably go back to it in April when weather better.
    Raymond, GLJ, Mailman and 2 others like this.
  11. Grimmith
    Grimmith Samurai
    363
    359
    63
    Iowa
    Finally got the frame, swingarm, sissy bar, engine mounts, triple tree, handlebar mounts, forward controls, and other various bike metals all sandblasted and gloss black powder coated :D, for a very very decent price . Stay tuned for the re-build. :rock:
    buzzword, tekk220, gggGary and 4 others like this.
  12. tekk220
    tekk220 XS650 Enthusiast
    86
    174
    33
    New York
    how decent... im about to get this done and looking for an idea of whats a good deal
    gggGary likes this.
  13. Grimmith
    Grimmith Samurai
    363
    359
    63
    Iowa
    well respectively, the guy that did this is a good friend of mine and his boss and him are friends so it was a simple discussion. It will start at around $150 depending on where you live, and that doesn't even include sandblasting. The more parts, the more cost. The color you want will again cost extra, unless you don't want a color like black or white. in my case I got gloss black.
    tekk220 and gggGary like this.
  14. Grimmith
    Grimmith Samurai
    363
    359
    63
    Iowa
    That was a fun several hours :D
    gggGary likes this.
  15. aldo5468
    aldo5468 Redleg XS650.com Supporter
    Finished a pigtail to adapt a gonzo box to my '82, using appropriate color-coded wiring from a salvage harness I bought many years ago. Won't be able to try it out until my bike is out of hibernation later this Spring. It will be a backup for the OEM TCI, which so far is working just fine but approaching 40 years old. Many, many thanks to those of you gurus who worked all this out for the rest of us!
  16. tekk220
    86
    174
    33
    New York
    picked up this 81 for $50. It was an offer I couldn’t refuse
    buzzword, Jim, jetmechmarty and 6 others like this.
  17. gggGary
    gggGary When a whole one is just too much. XS650.com Supporter Top Contributor
    That's bordering on bragging.... ;)
    Raymond, Jim and MrBultaco like this.
  18. tekk220
    86
    174
    33
    New York
    Hahaha you should be a detective
    Jim and gggGary like this.
  19. jetmechmarty
    jetmechmarty What should I put here? XS650.com Supporter Top Contributor
    That looks like mostly 1981 Special II. Very nice! Great score!
  20. 5twins
    20,870
    13,551
    813
    I scored one a bit less complete and in rougher shape for the same a few years back. Even if it never runs again, it's a gold mine for parts. Price some of the parts like wheels and engine side covers on eBay and you'll see. I see it has a nice early flanged alloy rim front wheel. If it is an '81, it should have the right engine cover with the oil sight glass.
    tekk220, gggGary and Jim like this.
Share This Page
