Seems to me that sometimes people want to convert to LED lights because they draw less power but then install resistors to make the flashers work. I'm no electrical genius but isn't that counterproductive?
- - - Ever notice that it's almost always a newer car that has one tail light or one brake light out! Hmmmm...
Yes, it does seem counter-productive, but even with the resistor, they will draw less current, but the best advantage is the longevity.
LED’s can be brighter but I find incandescent bulbs can be more easily seen when looking from an angle.
At 12 V, or even 14 V, 8 ohms is hardly a short. Ohms law is pretty basic stuff.Hey, KSHansen. This is buggin me! The resistors above are rated at 8ohms and 50W. 8 ohms, to me, is a short circuit. A short means heat and excessive current draw, and there is the counter productivity! Now, I'm not an electrical wizard, but 2 resistors in parallel will result in a resistance that is less than the smallest resistor. Therefore, now the resistance will be less than 8ohms which is an even greater short circuit. I am with you, Mr. Hansen. On our bikes, we are trying to reduce the load on our puny batteries. Note: An 1157 Led bulb has been in my tail light for about 6 years! No resistors needed on non-flashing circuits.
Experiment: I found a few resistors lying around and I settled for a 36-Ohm and a 400-Ohm. Both resistors worked, individually, in parallel with the new LED's, but the 36-Ohm got so hot that I couldn't hold it. The 400-Ohm stayed cool, or warm at the very least. It's a no-brainer which one I'm gonna use, if the new flasher doesn't work, and if the LED's burn out, well, they were only $10/pair!
Norway, like pretty much all of Europe, is 230 V and 50Hz. On ships, 60Hz is used, nut sure quite why though.Oh, and by the way, what is your standard household outlet voltage and frequency in Norway? Just curious! We are ~120V @ 60Hz.
Yes, using LED wherever possible is definitely a good idea, especially if using the oem alternator. Longer lifetime, brighter light (potentially), ability to use smaller gauge wiring, and less power consumption. For LED indicators, the only sensible solution is an electronic, load independent flasher. Personally, I would not be fussed about any old electro-mechanical self cancelling device. A good, bright indicator warning light is enough for me. If using a Motogadget M-Unit, the flasher is integrated in the M-unit, and that's it. For minimal and streamlined wiring, the M-unit would be hard to beat.Yes, I understand that 18Watts is 18Watts @ 12V, 460V or 10kV. But let's take the LED equivalent of a of a 60W, 120V incandescent bulb. It draws, for simplicity sake, 6W which is 1/10 of the incandescent bulb amperage. Perhaps I am wrong with the assumption that the 12V LED should be 10 times or at least 5 times more efficient than Edison's bulb.
Using your example, arctic, of an 18W bulb in a 12V circuit, we draw 1.5A. If the LED was 5 times more efficient, then the current would be 0.3A @ 3.6W and at 10 times the efficiency, it would draw 0.15A and use only 1.8W. A considerable reduction in Wattage and we can reduce the wire size, if necessary.
I can agree with Fred, why bother since it's only on 1/2 the time and only for a short time. Well, I'm bothering because my XS is basically my only hobby and I'm going to tinker it to death while I still can! And, Fred, I agree that screwing around with resistors that get so hot that they melt plastic is also kinda dumb.
I haven't found any info on the actual efficiency of a 12V LED. Anyone?
More useless knowledge..... aircraft use 115V at 400Hz.(Worked for 10 years on hydro power plants, so some useless knowledge is an inevitable occupational illness.....)
It's certainly not useless to me!More useless knowledge..... aircraft use 115V at 400Hz.
