Square Circle
What is the easiest way to fit up a 18 inch spoke wheel with disc brake to the oem swingarm? Will the Omars front wheel kit work ? Can you put an 18 inch rim on a stock 650 front hub?vI'm building a cafe, but currently have a 16 rear and 19 front mag.. Is the best handling set up the 18 and 19? I'm wanting to level out the ride..
Thanks for any suggestions you might have.
