From what I’ve read... these bikes vibrate pretty good. If it has a spring washer then no threadlocking compound. If not? Use some locktite. I changed the battery ground from the frame motor mount to the engine case bolt and was just a bolt with a plate washer and it had a thread locking compound on it.
My engine doesn't have any accessories to cover But seems like nothing with a gasket that comes to mind takes lock washers. Had starter gears cover seeping after a couple years. Noticed a couple of its bolts were looser than they started out. Handmade gasket using Fel-Pro rubberized paper might have lost resilience or something and quit pushing back on the bolt heads.
Maybe because a steel lock washer would chew up the alloy, and those bolts are removed and put back in more than most other fasteners on the bike = continuous, repeated, alloy chewing.
^Good point, plus aluminum compresses and doesn't hold tension. You sometimes see a lock washer over a flat washer, but have read that doesn't make sense, since the flat washer can turn, so the lock washer bite doesn't accomplish anything.
I've wondered about this as well, especially for the points/advance and alternator covers. No gaskets there, but no lock washers either, and I've never had them come loose. One thing I do is swap out the 10mm long screws on the alternator cover for longer ones. Seems Yamaha cheaped out here. Those 10mm long screws don't even engage all the available threads .....
