joestella28
Hi all,
I'm looking to put in a GSX1100 (GS1100 in the US I think) swing arm in to my tracker project. Like most swing arms, it's too wide. I'll only be able to narrow the swing arm so much and from what I have read on the swap, around 5mm needs to be taken off both the bosses on the inside of the frame,
My question is, how do you keep the face square? Being on the inside of the frame, it's not like you can pop it in a mill? I did wonder if you could finish the job with a facing tool as used on bicycle bottom bracket shells (i.e. http://bicyclepatents.com/facing-bottom-bracket-shells-on-the-catrike/1277/ ) but wonder if it would be man enough (even just to square it up).
If anyone has done this, I'd be keen to know how you went about it?
Many Thanks,
Joe
Many Thanks,
Joe
