Well, you're learning a little here but you still don't seem to understand completely how these stock 650 charging systems work. If the green wire on your regulator is supplying a regulated ground, just hooking it to the grounded brush isn't going to make it work. Turning the ground on and off to a brush that is already permanently grounded won't do shit. You need a different type regulator, one that regulates 12V power on the green wire. That's why I asked if you could I.D. the combined reg/rec you had, so maybe we could find some mounting instructions that had the wire colors labeled and maybe a spec sheet telling what type of regulator was in it. Since you bought the thing, you should have that info. Do you?
Voltage regulators for vehicle charging systems come in two basic types. They are categorized as being an "A" circuit type or a "B" circuit type. On the "A" circuit type, switched power is sent to one brush from the harness while the voltage regulator controls the charging output by varying the ground to the other brush. The later style 650 charging system uses this type. On the "B" circuit type, the regulator controls the power to one brush while the other is permanently grounded. The early 650 charging system (like yours) uses this type.
