1BigOkie
XS650 New Member
I have an 82 model, PO redid the wiring (its kind of atrocious but I will be replacing it once I make sure everything is working properly) It will start, run and drive until the battery gets low (and run bad after some distance, I think the coil is going out/getting hot.) I can not get it to charge, I tested the reg/rec yesterday (diode test) and with the red probe on the red wire and testing each of the stator (white) wires I got 1,1,1 (no change?) And with red on black to each I got 403,360,420. With the black probe on the red wire and testing each stator wire I got 420,408,400 and with the black probe on the black wire I got 1,1,1. I think it's good? I ohmed the rotor slip rings and got 5 ohms between them. Tested AC from the stator while running and got 24V AC going to the reg/rec. I need help, I'm very new to it but want to see her up and running right.
