xscessivecompulsive
Live 2 Ride, Ride 2 Live
Ok guys check this out! My bike has been running like a top after a fresh top end rebuild and broke down on me tonite! So a little history, The reason why I re built the top end was I had burnt exhaust valve on, (if I remember correctly the right side)! I took the head in to a very good machine shop and had them go over it! I replaced both exhaust valves with stainless ones from Mikes and the machine shop told me keep the same stock intakes as they appeared to be in good shape! After I got the head back, I purchased Mikes 650 stock cylinder kit with pistons,jugs, rings and installed! I had a brand new cam chain, a really good used cam and rockers and put it together to spec! So tonite Im taking a ride and while riding, I all of sudden heard a noise like something came loose and was rattling around in the engine! Right after that the bike acted like it was running on one clylinder and starting popping out of the right side exhaust! Just like before when I had a burnt valve! Now if that is the case again, what the hell would cause it to keep burning up a valve! Im running great scott pipes and pods, and after I did my first oil change I took a look at both plugs and they were the light gray tan color! So Im really scratchin my head on this one and to be honest dont know what the hell to think?? You guys have any suggestions on what might be going on?? Thanks in advance guys!
XsC
XsC
