Cribby
And the more I think of it the more I think you are right
Ant
Ant
If you follow the line of the spoke to the hub, it looks like you have the spokes in the wrong holes in the hub. From an inner spoke on one side of the hub count how many holes between its opposing spoke on the other side, then count on an original wheel and see if it’s the same, my guess yours will be one less. This will explain why your spokes seem too long. I will count mine tomorrow and let you knowJust a couple shots of a stock XS2 wheel and DB's side by side. Nothing is leaping out at me. Both you are certain the rim is XS2 not XS1 or 1B (clutching at straws)
View attachment 160727 View attachment 160728 View attachment 160729
GLJ, I think you might be on to something. Would explain my wheel. I intend to investigate further.DogBunny I think the your rim with the bentish spokes is not a XS2 rim. Yours ends with 201. I have 3 and all end with 202.
2A202, 2B202 and 2E202.
Gary's 3 rims also end with 202
I'm out of town again. When I get home at the end of the week I'll look and see if I have any loose XS2 spokes laying around. If so I'll measure and let you know the length of them.Hi
I’ve measured the new spokes and they are 185mm
The rim has been rechromed so hard to read but I think the numbers are 222, is that possible?
Ant
View attachment 161121 Like this
Rasputin, thanks for the pictures. Somehow I missed them until now. Yes, this might be my problem. Something else that I will look into.As you can see the inner spoke on one side of the valve goes to the blue mark, the inner spoke at the other side of the valve hole goes in the hole on the other side of the hub 5 and a half holes around. I say 5 and a half because the holes on either side of the hub are interspaces. When I build wheels I only put the inners in first then check run out and ovality, then the outers. Hope it helps. View attachment 161132
This is a stainless spoke from Mikes. I do not know exactly how a spoke should be measured. To me it looks like 184 to 185 mm.I’ve measured the new spokes and they are 185mm
