TerribleTabo1
$11,000
In choosing to make the bike very period correct, most of the sheet metal and the running gear required extensive reworking to fit the custom built XS650 hard-tail frame and motor combination. A set of custom made header pipes was also fabricated for the project that flow into a set of modified Big Twin 36 to 40 style mufflers.
The XSLA project features 18 inch black Big Twin Star Hub wheels with stainless steel spokes, Avon Safety Mileage tires, Edart front and rear Disc Brake conversion kits and Jay Brake master cylinders for both of the front brake and hydraulic clutch controls. The rear brake control assembly is fitted from a 58 to 69 Big Twin FL and the hydraulic clutch conversion uses a slave cylinder assembly from a Honda VFR.
Builder: Cycle Service Sales, LLC
High Bridge, NJ
William Giordano – Anthony Livelli
Phil Delano – Performance Welding
Lebanon Boro, NJ
Year/Model: 1980 Yamaha Custom
Powder Coater: Acme Powder Coating
Color: Federal Standard - Olive Green
Army
Pickup Only. (I will try my best to help if buyer wants to arrange shipping)
Engine/Transmission
Engine: Yamaha XS650 base
Crankshaft: 270 Re-phase by Heiden Tuning.
Cylinder: Mikes XS 750 Big Bore
Head: Ported & Polished by
Gary Hoos Racing
Carbs: 36 mm Mikuni VM (2)
Exhaust: Custom Fabricated
Ignition: Pamco 270 Re-phase
Coils: Mikes XS
Charging System: Sparks 3-phase
Transmission: Yamaha 5 speed
Primary Gears & Clutch: Heiden Tuning custom High Ratio
Hydraulic Clutch: Custom- Honda VFR slave cylinder
Final Drive: 530 Diamond Chain
Chassis
Frame: Custom made Hardtail with 28 degree rake
Front Fork: Big Twin Springer
Front wheel: 18” Star Hub Black
Rear wheel: 18” Star Hub Black
Front Brake: 11.5” Edart Disc Kit
Rear Brake: Edart Rear Disc Kit
Tires: 18” Avon Safety Mileage
Front Fender: WLA Reproduction
Rear Fender: WLA Reproduction
Accessories
Headlight: Springer – Halogen Bulb
Taillight: Modified Military Jeep – with LED lighting
Fuel Tanks: Modified Early Big Twin reproductions
Fuel Petcocks: Pingel
Handlebars: Modified Springer
Hand Controls: Jay Brake – Black
Mirrors: Modified WLA assemblies
Horn: 12 volt Springer with WLA face plate
Speedo: Military WLA Repro
Seat: Replica WLA army
Seat Springs: Indian 741
Floor Boards: Military WLA Repro
Floor Board Mounts: 45 & Big Twin
Rear Brake: 58 to 69 Big Twin Wagner style
Toolbox: Modified Harley Kidney Shaped
Chain Guard: Modified Big Twin Rigid
