mrbatavus
Recently acquired a 81 xs650 for free
I stripped the wiring down to whats need to run for now, as well as all other bike parts.
When i got it the kickstart lever did funny things, so i took it apart and reassembled it correctly. The seal looked good enough so I didn't change it. Went to Walmart and got some 15w40 diesel oil and filled it up.
I noticed the clutch lever wasn't doing anything with the bike in gear so I took off the side cover only to find a shiny ball bearing, i put it aside and left the cover off and put the bike in neutral.
I needed to see if the bike had spark so I took the spark plug out and placed in in such a way that i could see if i had spark when i kicked it over.
It didn't have spark, so after a quick peak at the wiring diagram i needed to hook the coil up to constant power as well as the other wires, and that hooking the coil up to the "accessory power" wire wasn't cutting it.
Hooked it up, had spark, shot some gum cutter down the carbs and after spinning the spark plug in it fired up and started idling.
The tank on this thing is pretty rusted inside, i filled it with rocks and gas and shook it with ok results but im still going to need an inline filter as well as a petcock rebuild, the seals were so bad i couldn't change the lever from where it was.
I ordered a set of ex500 ninja carbs offline and they literally pushed right on after removing one of the support brackets. I filled the floats with gas and it started right up and was idiling fine. I do need to remove them for a rebuild tho because they started overflowing with gas, either the floats are stuck or something, plus i read that you need to change the needles and jets to get the best ride out of them.
Il be keeping updates hopefully about the bike, id like to see it driving in a few weeks.
