jasper1252
- Messages
- 14
- Reaction score
- 2
- Points
- 1
Ok heres some info and pics on this bike. I first got it for 400$ off of ebay last january. I like odd things and wanted a bike like i havent seen before. First the engine has a total rebuild with a brand new topend 750cc kit from mikes xs. I also added their cam , performance clutch,sparx charging system, boyer brandson ignition, and mikuni carbs. I am curently installing a 5th gear overdrive that i have needed for sometime. The front of the frame is the original. I welded raked harley neck cups in the neck and installed the 41mm harley front end. The rear frame i built on a homemade jig and then designed the jackshaft for the 300mm rear tire. The wheels are from a bigdog not sure what year. The fuel tank is the original that i modified to be more sleek and fit the bike. The paint i did and it is black with candy orange flames with skulls and a marbleized base. Thats most of the basics on it ill be glad to answer any questions you have. This is also my first bike build, i normally mess with hot rod and rat rods ect.
