1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
XS650 No Theme Build
Discussion in 'The Garage' started by halfmile, May 24, 2018.
  1. Ratranger
    Ratranger XS650 Addict
    Great minds think alike? I chopped my frame in about the same place.
    rehar likes this.
  2. halfmile
    halfmile XS650 Junkie Top Contributor XS650.com Supporter
    907
    2,280
    243
    kansas
    This is the shock I was thinking about using. I`ve been looking on eBait and swing arms are dirt cheap (if it doesn`t say Radian on it anywhere) but I`m trying to use up all the parts I have left over from the last 3 builds and really would like to keep the cost under $800 not counting the parts I already have. I`m not really up for making spacers, chain clearance etc. Giving this one my best shot at keeping it simple.
  3. halfmile
    907
    2,280
    243
    kansas
    Heat index of only 107 today. Seemed like a good time to smooth out the tab removal and not mow the yard. I`ll mow it tomorrow when it`s 114 index instead. Build is moving like a snail in this heat.
  4. Mailman
    I hear you brother! Here in Phoenix the actual temperature is 110 degrees and breezy. The only benefit is we have super low humidity, so instead of sweating to death we just kinda look like dried figs.
  5. geedubya
    geedubya geedubya Top Contributor XS650.com Supporter
    G'day Bob,
    You are so lucky to have dry heat.
    Man here in the tropics during our wet season it may be 100+ and over 90% humidity.
    Doug/Skull can confirm this.
    I have heard that hell is a dry heat so perhaps you may feel at home one day, lol.
    GW
    TwoManyXS1Bs and Jim like this.
  6. halfmile
    907
    2,280
    243
    kansas
    Arctic Blast!! Polar Vortex?? Whatever, it only got to 98 degrees today so I got a little done on the build. I`m waiting on a Dog Bone for the linkage so I can start on the mono shock. Can`t be that hard I mean it`s just a spring with a hole on each end RIGHT??:shrug:
    No Theme Build 7-16 006.JPG No Theme Build 7-16 007.JPG No Theme Build 7-16 008.JPG No Theme Build 7-16 009.JPG
  7. halfmile
    907
    2,280
    243
    kansas
    Mounting tabs made and all welded up (monoshock part that is). Going in for upper dental implants tomorrow so I thought I`d better finish this first. A public ass kicking would be easier and much cheaper. 9 months now when this all heals completely I`m going t buy a 100 lb bag of pistachio nuts and eat every one.:D
    monoshock 001.JPG monoshock 002.JPG monoshock 003.JPG monoshock 004.JPG monoshock 005.JPG monoshock 006.JPG
    rehar, JRay77, MrBultaco and 3 others like this.
  8. CoconutPete
    CoconutPete 1979 XS650 Special
    Looks bonkers!
    You going to keep rocking the mags?
  9. halfmile
    907
    2,280
    243
    kansas
    IMHO the mag wheels stink out loud. However I`ve already set the suspension to the 16" rear wheel and the mags do have brand new tires. They look like S#*t on the bike and great on my budget. I was thinking there was 1 year that used a 16" alloy rear wire spoke wheel. If that is true I would change them both if I could find one.
    Seat and Tank are next?
  10. CoconutPete
    Yep, you can get a 16" spoked rear. There was one for sale on here not too long ago, but the hub was cut out.
    I have grown to like the mags, although I like them much better as a one-solid-color wheel than when they were "2-tone".
  11. halfmile
    907
    2,280
    243
    kansas
    After seeing Jim`s "Start Up" I finally got my ass in gear and did something on my No Theme Build for a change. I made a (functional I hope) swing arm brace, installed new brass bushings and made a gas tank mount. The brace has good clearance for the chain and dog bone but I`m going to use a 520 with 16-36 sprockets. It looks like the center stand will work too but I may not use it. I know I said in another thread that I was not going to use a new tank and seat but I miss poke. No, wait, that was my prom date:yikes:. I just flat out lied! I`m trying to get as much open wheel look as possible. Not planning to use the drum brake though. Tonight I`ll start on the seat rails and frame braces. I`d like to get this to the powder coater by the 1st week of Sept.
    No Theme Build 8-14-18 001.JPG No Theme Build 8-14-18 002.JPG No Theme Build 8-14-18 003.JPG No Theme Build 8-14-18 004.JPG No Theme Build 8-14-18 005.JPG No Theme Build 8-14-18 006.JPG No Theme Build 8-14-18 007.JPG No Theme Build 8-14-18 008.JPG No Theme Build 8-14-18 009.JPG No Theme Build 8-14-18 010.JPG No Theme Build 8-14-18 011.JPG No Theme Build 8-14-18 012.JPG
    rehar, RedRyder, TwoManyXS1Bs and 4 others like this.
  12. Jim
    Jim The thrill of victory and da agony of da feet. Top Contributor XS650.com Supporter
    Nice Phil!!!
    I got an extra disk mag if you need it.
    MaxPete and robinc like this.
  13. Robert Reed
    Robert Reed XS650 Addict
    Love this angle!
    [​IMG]
    MaxPete likes this.
  14. halfmile
    907
    2,280
    243
    kansas
    Today I made the frame for the Champion seat. I still have to make some supports and notch the front tubes for the final fit. Probably finish this up tomorrow and move on to the center brace and upper motor mount. Thinking seriously about new triple trees. Maybe inverted forks??
    champion seat frame 001.JPG champion seat frame 002.JPG champion seat frame 006.JPG champion seat frame 008.JPG champion seat frame 008.JPG champion seat frame 003.JPG champion seat frame 005.JPG champion seat frame 009.JPG champion seat frame 004.JPG champion seat frame 012.JPG champion seat frame 013.JPG champion seat frame 011.JPG champion seat frame 010.JPG
    rehar, MrBultaco, robinc and 3 others like this.
  15. halfmile
    907
    2,280
    243
    kansas
    Today I welded the upper seat rail, fitted the seat and looked at it. Then I went in the house and drank a Coke, ate ice cream, and watched TV.
    champion seat frame 001.JPG champion seat frame 002.JPG champion seat frame 003.JPG
    59Tebo, TwoManyXS1Bs, robinc and 3 others like this.
  16. halfmile
    907
    2,280
    243
    kansas
    Got these seat rail uprights made today. they had to be angled inward and sit vertical to clear the seat. Between all the phone calls, text messages, girl friends BS, and countless interruptions it only took 7 hrs:shrug:.
    frame  uprights 001.JPG frame  uprights 002.JPG frame  uprights 003.JPG frame  uprights 004.JPG frame  uprights 005.JPG
  17. halfmile
    907
    2,280
    243
    kansas
    Last night I drew up templates for the frame gussets, transferred them to 14ga sheet metal, punched holes, drilled them in the different sizes, chamfered the edges then cut them out on the band saw and tack welded them in place. I still have to make a lower center brace and new upper motor mounts. (more room to install and remove the motor) I`m really getting burnt out on this frame & swing arm. Probably should rename this thread the "monkey spank build"??
    frame gussets 011.JPG frame gussets 006.JPG frame gussets 005.JPG frame gussets 004.JPG frame gussets 003.JPG frame gussets 002.JPG frame gussets 001.JPG frame gussets 007.JPG
  18. Jim
    I think it needs more holes......:rolleyes:
    SAFU, TwoManyXS1Bs and robinc like this.
  19. halfmile
    907
    2,280
    243
    kansas
    Yeah your right Jim. I`m not done yet.:thumbsup:
    Jim and robinc like this.
  20. halfmile
    907
    2,280
    243
    kansas
    Got the frame 70% welded today. Still have more brackets to make for Master Cyl and swing arm brake stay, coil mount, and who knows what else?? I`m still shooting for Sept 1`st powder coat. We`ll see?
    no theme welding 002.JPG no theme welding 003.JPG no theme welding 004.JPG no theme welding 005.JPG no theme welding 006.JPG no theme welding 007.JPG no theme welding 008.JPG no theme welding 009.JPG
Share This Page
